Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, removing the back panel, and detach the power button.
  1. Using a T2  Torx Screwdriver, remove two screws from the bottom edge of the phone.
    • Using a T2 Torx Screwdriver, remove two screws from the bottom edge of the phone.
  2. Apply the suction tool to the back panel near the bottom edge. Carefully slide the device pick between the back panel and bottom edge.
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious do not damage phone display and or inside components while using pry tool and suction tool.
  3. Take the end of the opening tool and push the old power button out of its socket.
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Place the new BLU Grand M2 power button in the socket.
    • Place the new BLU Grand M2 power button in the socket.
Conclusione
Alan Rodriguez
Membro da: 10/09/2018
299 Reputazione
2 Guide realizzate
Gateway, Team S1-G3, Luster Fall 2018 Membro di Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Membri
4 Guide realizzate
Don’t forget to remove the SIM card
Jonathan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 200
