Salta al contenuto principale
Blu Grand M Vibrator Replacement
Cosa ti serve
  1. Blu Grand M Vibrator Replacement, Battery: passo 1, immagine 1 di 2 Blu Grand M Vibrator Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Vibrator Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Vibrator Replacement: passo 3, immagine 1 di 3 Blu Grand M Vibrator Replacement: passo 3, immagine 2 di 3 Blu Grand M Vibrator Replacement: passo 3, immagine 3 di 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Vibrator Replacement: passo 4, immagine 1 di 2 Blu Grand M Vibrator Replacement: passo 4, immagine 2 di 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Vibrator Replacement, Speaker: passo 5, immagine 1 di 2 Blu Grand M Vibrator Replacement, Speaker: passo 5, immagine 2 di 2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Vibrator Replacement: passo 6, immagine 1 di 3 Blu Grand M Vibrator Replacement: passo 6, immagine 2 di 3 Blu Grand M Vibrator Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
  7. Blu Grand M Vibrator Replacement, Microphone: passo 7, immagine 1 di 2 Blu Grand M Vibrator Replacement, Microphone: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the black wire with a pair of tweezers.
    • The black wire can swivel out of the way to easily access the next microphone.
  8. Blu Grand M Vibrator Replacement: passo 8, immagine 1 di 2 Blu Grand M Vibrator Replacement: passo 8, immagine 2 di 2
    • Use a pair of tweezers to remove the orange data cable as shown.
  9. Blu Grand M Vibrator Replacement: passo 9, immagine 1 di 3 Blu Grand M Vibrator Replacement: passo 9, immagine 2 di 3 Blu Grand M Vibrator Replacement: passo 9, immagine 3 di 3
    • There will be glue holding the wires down, and they can be glued back in place after.
    • Use the plastic opening tool to lift the microphone out of place.
    • Use a pair of tweezers to lift the microphone out of the phone.
  10. Blu Grand M Vibrator Replacement, Vibrator: passo 10, immagine 1 di 2 Blu Grand M Vibrator Replacement, Vibrator: passo 10, immagine 2 di 2
    • To remove the vibrator, use the plastic opening tool to pry it out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 137
