Salta al contenuto principale
Blu Dash 5.0 Dual SIM Speaker Replacement
Cosa ti serve
  1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Make sure device is disconnected and turned off.
    • Locate the groove at the bottom left corner of the phone.
    • Insert the plastic opening tool in the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 2, immagine 1 di 1
    • Pry the battery out from the back of the phone using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
    • The red circles are screw holes that hold the 3.5mm length Phillips screw.
    • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
  4. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, immagine 1 di 3 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, immagine 2 di 3 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, immagine 3 di 3
    • Remove the back panel of the phone with your hand.
    • Carefully remove the plastic back panel to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the antenna cable connectors using a spudger.
  6. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 6, immagine 1 di 1
    • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
  7. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 7, immagine 1 di 2 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Flip the ZIF flap up with tweezers.
    • Remove the ribbon cable with tweezers.
    • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
  8. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 8, immagine 1 di 2 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 8, immagine 2 di 2
    • Remove the speaker panel with the plastic opening tool.
    • The panel is glued onto the device and will require extra force to remove.
Conclusione
Mukish Kumar Munyady
Membro da: 01/30/17
201 Reputazione
2 Guide realizzate
IUPUI, Team 1-1, Baechle Spring 2017 Membro di IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 279
