Salta al contenuto principale
Blu Dash 5.0 Dual SIM Motherboard Replacement
Cosa ti serve
  1. Blu Dash 5.0 Dual SIM Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 2, immagine 1 di 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
  3. Blu Dash 5.0 Dual SIM Motherboard Replacement, Display Cable: passo 3, immagine 1 di 1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
  4. Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 4, immagine 1 di 2 Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 4, immagine 2 di 2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
  5. Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 5, immagine 1 di 3 Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 5, immagine 2 di 3 Blu Dash 5.0 Dual SIM Motherboard Replacement: passo 5, immagine 3 di 3
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
  6. Blu Dash 5.0 Dual SIM Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Blu Dash 5.0 Dual SIM Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Blu Dash 5.0 Dual SIM Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Using the tweezers, lift the tabs where the cables are connected, this unlocks the cables. The cables will slide out of sockets easily when they are unlocked. Pull from wire using tweezers as pictured.
    • The red rectangles represent where the cable's are located.
    • The orange rectangles are where the cables pug into the ports. This is where you want to apply the tweezers.
    • There are two black tabs and one blue tab.
Conclusione
Altre 7 persone hanno completato questa guida.
UMass Dartmouth, Team 4-7, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Membri
3 Guide realizzate
3 Commenti
i am having an issue with the display screen at first it fell from my mom when she pick it up there was a white line at the extreme top of the phone and after a while of use all of a sudden WHILE using it the white line started appearing all over in a horizontal fashion am afraid of touching anything on the mother board without knowing what it does the screen still works fine its just the horizontal lines all over and the colour quality kinda faded
keanu chin - Replica
I disabled the web viewer accidentally. I then realised that after I did that, the keypad locked as usual. After that the google talk option came to front of the screen, where I would need to log it. Its blocking the keyboard basically for I have no option to type my password in order to log in. How can I fix this problem.
cadimoniquebell - Replica
Slot1 is messed up can you use slot 2. For simcard
Margie White - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 6,024
