Salta al contenuto principale
Blu Dash 5.0 Dual SIM Battery Replacement
Cosa ti serve
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: passo 2, immagine 1 di 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
Conclusione
Altre 5 persone hanno completato questa guida.
UMass Dartmouth, Team 4-7, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Membri
3 Guide realizzate
Un commento
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,053
