Salta al contenuto principale
Blu Dash 5.0 Dual SIM Back Camera Replacement
Cosa ti serve
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: passo 1, immagine 1 di 2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: passo 1, immagine 2 di 2
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 2, immagine 1 di 1
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 3, immagine 1 di 1
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, immagine 1 di 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, immagine 2 di 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, immagine 3 di 3
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, immagine 1 di 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, immagine 2 di 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Conclusione
Mukish Kumar Munyady
Membro da: 01/30/17
201 Reputazione
2 Guide realizzate
IUPUI, Team 1-1, Baechle Spring 2017 Membro di IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 382
