Salta al contenuto principale
Blackview BV9800 Pro Screen Replacement
Cosa ti serve
  1. Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: passo 1, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: passo 1, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: passo 1, immagine 3 di 3
    • Flip the phone over.
    • Remove the four T5 screws.
    • Remove the single T5 screw from the bottom, next to the charging port.
  2. Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: passo 2, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: passo 2, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: passo 2, immagine 3 di 3
    • Remove the screws from the sides.
    • Remove the screws holding the camera frame.
  3. Blackview BV9800 Pro Screen Replacement, Removing side bezels: passo 3, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Removing side bezels: passo 3, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Removing side bezels: passo 3, immagine 3 di 3
    • Pry out the sim car holder
    • It has a dual sim card holder, but to remove the second tray you need a pin or an iphone sim card opener to push it out.
    • Use a spudger or a utility knife to pry off the side bezels.
  4. Blackview BV9800 Pro Screen Replacement, Separate the back cover: passo 4, immagine 1 di 2 Blackview BV9800 Pro Screen Replacement, Separate the back cover: passo 4, immagine 2 di 2
    • Pry in one corner and separate the back.
  5. Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: passo 5, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: passo 5, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: passo 5, immagine 3 di 3
    • Use a plastic spudger to disconnect the flex connectors.
  6. Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: passo 6, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: passo 6, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: passo 6, immagine 3 di 3
    • Use a plastic spudger to disconnect the flex connector and the antenna
  7. Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: passo 7, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: passo 7, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
    • Remove the screws.
    • The last screw is under a tamper-proof sticker
    • Use plastic spudger or tweezers to disconnect the camera flex cable from the top
    • Gently lift up the plasctic cover from the right side. It is still connected to the board below!
    • Disconnect the flex cable
    • Disconnect the antenna
  8. Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: passo 8, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: passo 8, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: passo 8, immagine 3 di 3
    • Remove the screws from the battery cover
    • Carefully release the ribbon cable from the battery shield. It is stuck down at two points.
  9. Blackview BV9800 Pro Screen Replacement, Disconnect connectors: passo 9, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: passo 9, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: passo 9, immagine 3 di 3
    • Disconnect the flex connectors and remove the battery
  10. Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: passo 10, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: passo 10, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: passo 10, immagine 3 di 3
    • Remove two J000 screws
    • Carefully pry up the camera. Heat from the glass side if necessary.
    • Unscrew and remove the camera assembly
  11. Blackview BV9800 Pro Screen Replacement, Remove light sensor: passo 11, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Remove light sensor: passo 11, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Remove light sensor: passo 11, immagine 3 di 3
    • Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
    • Using tweezers slowly and carefully lift out the light sensor
  12. Blackview BV9800 Pro Screen Replacement, Remove audio jack: passo 12, immagine 1 di 3 Blackview BV9800 Pro Screen Replacement, Remove audio jack: passo 12, immagine 2 di 3 Blackview BV9800 Pro Screen Replacement, Remove audio jack: passo 12, immagine 3 di 3
    • Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
    • Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
    • Lift it out and transfer to the new screen.
  13. Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: passo 13, immagine 1 di 2 Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: passo 13, immagine 2 di 2
    • Gently peel the flex cable u p and transfer to the new assembly.
    • Heat it up if the adhesive is too strong.
    • Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
Conclusione
Altre 9 persone hanno completato questa guida.
honakrisi
Membro da: 01/28/20
4.033 Reputazione
8 Guide realizzate
3Commenti sulla guida
You saved my mobile phone. Even I did not replace the screen, I just replace the battery. I forgot some connectors but your post remind me and the mobile back to work!
Colin Wen - Replica Condividi
I’m glad that you managed to save your device!
honakrisi - Condividi
Where can I get black view repair shop in Ghana and their number
Emmanuel offei - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 117
Tutti i Tempi: 5,930
