Salta al contenuto principale
Blackstone Cascade Pro Fan Replacement
Cosa ti serve
  1. Blackstone Cascade Pro Fan Replacement, Fan: passo 1, immagine 1 di 3 Blackstone Cascade Pro Fan Replacement, Fan: passo 1, immagine 2 di 3 Blackstone Cascade Pro Fan Replacement, Fan: passo 1, immagine 3 di 3
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: passo 2, immagine 1 di 2 Blackstone Cascade Pro Fan Replacement: passo 2, immagine 2 di 2
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: passo 3, immagine 1 di 3 Blackstone Cascade Pro Fan Replacement: passo 3, immagine 2 di 3 Blackstone Cascade Pro Fan Replacement: passo 3, immagine 3 di 3
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: passo 4, immagine 1 di 2 Blackstone Cascade Pro Fan Replacement: passo 4, immagine 2 di 2
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: passo 5, immagine 1 di 3 Blackstone Cascade Pro Fan Replacement: passo 5, immagine 2 di 3 Blackstone Cascade Pro Fan Replacement: passo 5, immagine 3 di 3
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 306
