Salta al contenuto principale
Blackberry RIM 7250 Keyboard Replacement
Cosa ti serve
  1. Blackberry RIM 7250 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Keyboard Replacement: passo 2, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 2, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 2, immagine 3 di 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Keyboard Replacement: passo 3, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 3, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 3, immagine 3 di 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Keyboard Replacement, Back Housing: passo 4, immagine 1 di 2 Blackberry RIM 7250 Keyboard Replacement, Back Housing: passo 4, immagine 2 di 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Keyboard Replacement: passo 5, immagine 1 di 2 Blackberry RIM 7250 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Keyboard Replacement: passo 6, immagine 1 di 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Keyboard Replacement: passo 7, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 7, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 7, immagine 3 di 3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Keyboard Replacement, Front Housing: passo 8, immagine 1 di 2 Blackberry RIM 7250 Keyboard Replacement, Front Housing: passo 8, immagine 2 di 2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Keyboard Replacement: passo 9, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 9, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement: passo 9, immagine 3 di 3
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Keyboard Replacement, Keyboard: passo 10, immagine 1 di 3 Blackberry RIM 7250 Keyboard Replacement, Keyboard: passo 10, immagine 2 di 3 Blackberry RIM 7250 Keyboard Replacement, Keyboard: passo 10, immagine 3 di 3
    • Push the keyboard from the front view to separate it from the front housing.
  11. Blackberry RIM 7250 Keyboard Replacement: passo 11, immagine 1 di 2 Blackberry RIM 7250 Keyboard Replacement: passo 11, immagine 2 di 2
    • Hold the front housing with one hand and grab the keyboard with the other.
    • Pull each piece away from each other to remove the keyboard.
Conclusione
Noah Eckert
Membro da: 11/05/18
519 Reputazione
5 Guide realizzate
IUPUI, Team S2-G4, Baechle Fall 2018 Membro di IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 440
