Salta al contenuto principale
Blackberry Pearl 8100 SIM Card Replacement
  1. Blackberry Pearl 8100 SIM Card Replacement, Battery: passo 1, immagine 1 di 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: passo 3, immagine 1 di 1
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  3. Blackberry Pearl 8100 SIM Card Replacement: passo 4, immagine 1 di 1
    • Lift the metal casing.
    • Insert an SD Card.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 34-57, Forte Spring 2010 Membro di Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 9,240
