Salta al contenuto principale
Blackberry KeyONE Speaker Replacement
Cosa ti serve
  1. Blackberry KeyONE  Speaker Replacement, Remove top cover: passo 1, immagine 1 di 1
    • Carefully remove the top plastic cover. It is hold in place by adhesive.
  2. Blackberry KeyONE  Speaker Replacement, Remove upper frame: passo 2, immagine 1 di 2 Blackberry KeyONE  Speaker Replacement, Remove upper frame: passo 2, immagine 2 di 2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. Blackberry KeyONE  Speaker Replacement, Replace speaker: passo 3, immagine 1 di 1
    • Now the speaker just slides out.
Conclusione
Altre 3 persone hanno completato questa guida.
raven
Membro da: 09/02/15
1.080 Reputazione
4 Guide realizzate
3 Commenti
Trickiest part was removing the top piece. I used a razor blade to lift the edge, then a guitar pick to finish pulling it up. Thanks for the instructions.
Brian Wiebe - Replica
Be careful with the razor blade or it will slice the top of the flex which you can see folded over the top of the frame. This is not what you will really want to do as you will now be replacing the flex too.
eric Aspinall - Replica
thanks for the guide! was unsure how the phone came apart besides the back cover. took a few tries to get a hang of luckily i had started on the ones with totalled enclosures.
echow2001 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,958
