Salta al contenuto principale
Blackberry Curve 9300 Speaker Replacement
Cosa ti serve
  1. Blackberry Curve 9300 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: passo 2, immagine 1 di 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: passo 3, immagine 1 di 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: passo 4, immagine 1 di 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: passo 5, immagine 1 di 2 Blackberry Curve 9300 Speaker Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: passo 7, immagine 1 di 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: passo 8, immagine 1 di 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: passo 9, immagine 1 di 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: passo 10, immagine 1 di 1
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: passo 11, immagine 1 di 1
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: passo 12, immagine 1 di 3 Blackberry Curve 9300 Speaker Replacement: passo 12, immagine 2 di 3 Blackberry Curve 9300 Speaker Replacement: passo 12, immagine 3 di 3
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: passo 13, immagine 1 di 2 Blackberry Curve 9300 Speaker Replacement: passo 13, immagine 2 di 2
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: passo 14, immagine 1 di 2 Blackberry Curve 9300 Speaker Replacement: passo 14, immagine 2 di 2
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: passo 15, immagine 1 di 1
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: passo 16, immagine 1 di 2 Blackberry Curve 9300 Speaker Replacement: passo 16, immagine 2 di 2
    • Lift the speaker up to remove the speaker from phone.
Conclusione
Altre 6 persone hanno completato questa guida.
Alek Squires
Membro da: 09/30/13
431 Reputazione
2 Guide realizzate
Cal Poly, Team 14-7, Forte Fall 2013 Membro di Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,188
