Salta al contenuto principale
Blackberry Curve 9300 Screen Replacement
Cosa ti serve
  1. Blackberry Curve 9300 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: passo 2, immagine 1 di 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: passo 3, immagine 1 di 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: passo 4, immagine 1 di 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: passo 5, immagine 1 di 2 Blackberry Curve 9300 Screen Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: passo 7, immagine 1 di 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: passo 8, immagine 1 di 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: passo 9, immagine 1 di 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: passo 10, immagine 1 di 1
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: passo 11, immagine 1 di 1
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: passo 12, immagine 1 di 3 Blackberry Curve 9300 Screen Replacement: passo 12, immagine 2 di 3 Blackberry Curve 9300 Screen Replacement: passo 12, immagine 3 di 3
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: passo 13, immagine 1 di 2 Blackberry Curve 9300 Screen Replacement: passo 13, immagine 2 di 2
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: passo 14, immagine 1 di 2 Blackberry Curve 9300 Screen Replacement: passo 14, immagine 2 di 2
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: passo 15, immagine 1 di 3 Blackberry Curve 9300 Screen Replacement: passo 15, immagine 2 di 3 Blackberry Curve 9300 Screen Replacement: passo 15, immagine 3 di 3
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Conclusione
Altre 9 persone hanno completato questa guida.
Alek Squires
Membro da: 09/30/13
431 Reputazione
2 Guide realizzate
Cal Poly, Team 14-7, Forte Fall 2013 Membro di Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Membri
5 Guide realizzate
Un commento
would appreciate new ldc part # and order info! - - !
Donald Burgo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,830
