Salta al contenuto principale
Blackberry Curve 8320 Speaker Replacement
Cosa ti serve
  1. Blackberry Curve 8320 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Blackberry Curve 8320 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: passo 2, immagine 1 di 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, immagine 1 di 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, immagine 2 di 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, immagine 3 di 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: passo 4, immagine 1 di 2 Blackberry Curve 8320 Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: passo 5, immagine 1 di 2 Blackberry Curve 8320 Speaker Replacement: passo 5, immagine 2 di 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: passo 7, immagine 1 di 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, immagine 1 di 3 Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, immagine 2 di 3 Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, immagine 3 di 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: passo 9, immagine 1 di 2 Blackberry Curve 8320 Speaker Replacement: passo 9, immagine 2 di 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: passo 10, immagine 1 di 3 Blackberry Curve 8320 Speaker Replacement: passo 10, immagine 2 di 3 Blackberry Curve 8320 Speaker Replacement: passo 10, immagine 3 di 3
    • Remove the back case.
    • The speaker is located on the back case.
Conclusione
Cal Poly, Team 3-6, Regan Fall 2011 Membro di Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,987
