Introduzione
This guide will show you how to:
- Remove the battery
- Remove the front panel
- Replace the LCD screen
Parti
Nessuna parte richiesta.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
Quasi finito!
Conclusione
