Introduzione
This replacement guide will show you how to replace your Blackberry Bold 9900 power/volume button which is attached to the midframe. You will need to follow several prerequisite guides in order to get to this point but it will help you increase the length of Blackberry’s life and function.
Cosa ti serve
Place phone screen down.
Use your finger to life upward on the battery case.
Pull the cover away from the battery.
The Mini-SIM card is located inside the red rectangle.
To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
The MicroSD card is located where the red rectangle is shown.
To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
Lift the bezel at the bottom of the phone up and peel it away from the phone.
Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
