Salta al contenuto principale
Blackberry Bold 9900 Motherboard Replacement
Cosa ti serve
  1. Blackberry Bold 9900 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Motherboard Replacement: passo 2, immagine 1 di 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Motherboard Replacement, MicroSD card: passo 3, immagine 1 di 2 Blackberry Bold 9900 Motherboard Replacement, MicroSD card: passo 3, immagine 2 di 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Motherboard Replacement, Keyboard: passo 4, immagine 1 di 2 Blackberry Bold 9900 Motherboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Motherboard Replacement: passo 5, immagine 1 di 2 Blackberry Bold 9900 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Motherboard Replacement: passo 6, immagine 1 di 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Motherboard Replacement: passo 7, immagine 1 di 2 Blackberry Bold 9900 Motherboard Replacement: passo 7, immagine 2 di 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  8. Blackberry Bold 9900 Motherboard Replacement, Mini-SIM removal: passo 8, immagine 1 di 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  9. Blackberry Bold 9900 Motherboard Replacement, Back Case: passo 9, immagine 1 di 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Motherboard Replacement: passo 10, immagine 1 di 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
  11. Blackberry Bold 9900 Motherboard Replacement, Power/Volume Button: passo 11, immagine 1 di 3 Blackberry Bold 9900 Motherboard Replacement, Power/Volume Button: passo 11, immagine 2 di 3 Blackberry Bold 9900 Motherboard Replacement, Power/Volume Button: passo 11, immagine 3 di 3
    • Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
  12. Blackberry Bold 9900 Motherboard Replacement: passo 12, immagine 1 di 1
    • Lift the midframe, which contains the power/volume buttons, off of the motherboard and screen.
  13. Blackberry Bold 9900 Motherboard Replacement, Motherboard: passo 13, immagine 1 di 3 Blackberry Bold 9900 Motherboard Replacement, Motherboard: passo 13, immagine 2 di 3 Blackberry Bold 9900 Motherboard Replacement, Motherboard: passo 13, immagine 3 di 3
    • Using a spudger, gently walk the display cable out from the motherboard.
    • When it seems it has become loose enough, remove it by pinching the ribbon firmly with your fingers and gently sliding it the rest of the way out.
  14. Blackberry Bold 9900 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the motherboard from the screen.
Conclusione
Sarah Westberg
Membro da: 03/11/19
23.131 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,327
