Salta al contenuto principale
Blackberry Bold 9900 Back Case Replacement
Cosa ti serve
  1. Blackberry Bold 9900 Back Case Replacement, Battery: passo 1, immagine 1 di 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: passo 2, immagine 1 di 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: passo 3, immagine 1 di 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: passo 4, immagine 1 di 2 Blackberry Bold 9900 Back Case Replacement, MicroSD card: passo 4, immagine 2 di 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: passo 5, immagine 1 di 2 Blackberry Bold 9900 Back Case Replacement, Keyboard: passo 5, immagine 2 di 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: passo 6, immagine 1 di 2 Blackberry Bold 9900 Back Case Replacement: passo 6, immagine 2 di 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: passo 7, immagine 1 di 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: passo 8, immagine 1 di 2 Blackberry Bold 9900 Back Case Replacement: passo 8, immagine 2 di 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: passo 9, immagine 1 di 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: passo 10, immagine 1 di 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
Conclusione
Altre 3 persone hanno completato questa guida.
Sowmika
Membro da: 01/30/18
253 Reputazione
2 Guide realizzate
Baylor, Team S1-G4, Johnson Spring 2018 Membro di Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,434
