Salta al contenuto principale
Blackberry Bold 9650 Keypad Replacement
Cosa ti serve
  1. Blackberry Bold 9650 Keypad Replacement, Battery: passo 1, immagine 1 di 2 Blackberry Bold 9650 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Keypad Replacement: passo 2, immagine 1 di 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Keypad Replacement, SIM Card: passo 3, immagine 1 di 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Keypad Replacement: passo 4, immagine 1 di 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Keypad Replacement, Back Chassis: passo 5, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Keypad Replacement: passo 6, immagine 1 di 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Keypad Replacement: passo 7, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Keypad Replacement: passo 8, immagine 1 di 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Keypad Replacement, Mother Board: passo 9, immagine 1 di 1
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Keypad Replacement: passo 10, immagine 1 di 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Keypad Replacement: passo 11, immagine 1 di 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Keypad Replacement: passo 12, immagine 1 di 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Keypad Replacement, Faceplate: passo 13, immagine 1 di 2 Blackberry Bold 9650 Keypad Replacement, Faceplate: passo 13, immagine 2 di 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  14. Blackberry Bold 9650 Keypad Replacement, Keypad: passo 14, immagine 1 di 1
    • Lift the keypad out of the the front cover.
Conclusione
Altre 4 persone hanno completato questa guida.
Ryan
Membro da: 03/12/12
696 Reputazione
11 Guide realizzate
Clemson, Team 2-5, Benson Spring 2012 Membro di Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 15
Tutti i Tempi: 7,247
