Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Using your fingernails, lift the sides of the battery.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Orient the device so the screen is facing the ground.
    • Orient the device so the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Gently pull out the SIM card.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  6. Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  7. Orient the device so that the screen is facing you.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  8. Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  9. Remove the back chassis by gently pulling the chassis back and forth.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  10. Use a plastic pry tool to  remove the speaker.
    • Use a plastic pry tool to remove the speaker.
    • Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
Conclusione
Ryan
Membro da: 12/03/2012
642 Reputazione
11 Guide realizzate
Clemson, Team 2-5, Benson Spring 2012 Membro di Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,843
