1. Place your Blackberry facedown in front of you.
    • Place your Blackberry facedown in front of you.
  2. Press the cover release button on the bottom of your device. Lift and remove the back cover.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. From the top, use your fingernail to lift the battery out.
    • From the top, use your fingernail to lift the battery out.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the SIM card.
    • Remove the SIM card.
  6. Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  7. Use the plastic opening tool to remove the rear case.
    • Use the plastic opening tool to remove the rear case.
  8. Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  9. Locate the volume toggle on the main frame of the phone.
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  10. Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
Kelly
Membro da: 18/01/2012
566 Reputazione
6 Guide realizzate
Cal Poly, Team 8-17, Maness Winter 2012 Membro di Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,278
