Salta al contenuto principale
Introduzione
Disassembling the motherboard in the rear of the Blackberry allows you to get to the LCD screen and keypad.
Parti
Nessuna parte specificata.
  1. Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone. Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Use a pick or plastic opening tool to push the clips holding the rear away from you. Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  6. Repeat the process of unlatching the clips for the top section of the Blackberry.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  7. Slide the rear panel forward to reveal the motherboard. Slide the rear panel forward to reveal the motherboard.
    • Slide the rear panel forward to reveal the motherboard.
  8. Remove the indicated screws using a T6 Torx screwdriver. Remove the indicated screws using a T6 Torx screwdriver.
    • Remove the indicated screws using a T6 Torx screwdriver.
  9. Remove the motherboard. Remove the indicated screw using the T6 Torx screwdriver.
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  10. Pull the metal plate away from the front panel of the cell phone. Pull the metal plate away from the front panel of the cell phone.
    • Pull the metal plate away from the front panel of the cell phone.
  11. Place the faceplate face-down and the interior of the phone face-up, as shown.
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
Conclusione
Nathan
Membro da: 18/01/2010
31 Reputazione
6 Guide realizzate
Cal Poly, Team 5-7, Forte Winter 2010 Membro di Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,490
