Introduzione
This guide outlines how to do initial disassembly for the device and doubles as prerequisites for other guides.
Parti
Nessuna parte richiesta.
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
Aggiungi Commento
Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
Aggiungi Commento
  • Remove the battery by pushing against it from the right and then pulling towards you.
Aggiungi Commento
  • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
Aggiungi Commento
  • Use a plastic opening tool or your fingernails to remove the plastic backing.
  • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
Aggiungi Commento
  • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
  • Place the four screws released from the phone in a plastic bag.
Aggiungi Commento
  • The black battery casing and logic board can now be separated for the following steps.
Aggiungi Commento
Conclusione
kelogan
Membro da: 04/11/2009
1 Reputazione
2 Guide realizzate
Cal Poly, Team 9-17, Regan Fall 2009 Membro di Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,061
