Salta al contenuto principale
BlackBerry Z10 Motherboard Assembly Replacement
Cosa ti serve
  1. BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: passo 1, immagine 1 di 2 BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: passo 1, immagine 2 di 2
    • This is the easiest repair I've completed yet.
  2. BlackBerry Z10 Motherboard Assembly Replacement: passo 2, immagine 1 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 2, immagine 2 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 2, immagine 3 di 3
    • The rear panel pops off easily. Grab the opening at the bottom and work your way around.
  3. BlackBerry Z10 Motherboard Assembly Replacement: passo 3, immagine 1 di 2 BlackBerry Z10 Motherboard Assembly Replacement: passo 3, immagine 2 di 2
    • There is NO adhesive on this device. NO ADHESIVE!!
  4. BlackBerry Z10 Motherboard Assembly Replacement: passo 4, immagine 1 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 4, immagine 2 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 4, immagine 3 di 3
    • There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
  5. BlackBerry Z10 Motherboard Assembly Replacement: passo 5, immagine 1 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 5, immagine 2 di 3 BlackBerry Z10 Motherboard Assembly Replacement: passo 5, immagine 3 di 3
    • Disconnect the logic board connector near the top and left side.
    • Underneath the connector on the left side, there's two other connectors. Disconnect those.
    • Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
Conclusione
Altre 21 persone hanno completato questa guida.
2 Commenti
For what is the second Screwdriver and what size is the right on?
Stefan Schenk - Replica
Will changing the motherboard assembly change my imei. I am wondering if I need to check the imei of the new motherboard to make sure it isn’t from a flag phone before install it.
phnark - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 17,186
