Salta al contenuto principale
BlackBerry World Edition 8830 Trackball Replacement
Cosa ti serve
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: passo 1, immagine 1 di 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: passo 1, immagine 2 di 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: passo 1, immagine 3 di 3
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
  2. BlackBerry World Edition 8830 Trackball Replacement: passo 2, immagine 1 di 2 BlackBerry World Edition 8830 Trackball Replacement: passo 2, immagine 2 di 2
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
  3. BlackBerry World Edition 8830 Trackball Replacement: passo 3, immagine 1 di 1
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
Conclusione
tbace
Membro da: 04/18/12
28 Reputazione
2 Guide realizzate
Cal Poly, Team 17-27, Amido Spring 2012 Membro di Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,034
