Salta al contenuto principale
BlackBerry World Edition 8830 Keyboard Replacement
Cosa ti serve
  1. BlackBerry World Edition 8830 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 BlackBerry World Edition 8830 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 BlackBerry World Edition 8830 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 Keyboard Replacement, Front and Back Casing: passo 3, immagine 1 di 2 BlackBerry World Edition 8830 Keyboard Replacement, Front and Back Casing: passo 3, immagine 2 di 2
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 Keyboard Replacement: passo 4, immagine 1 di 3 BlackBerry World Edition 8830 Keyboard Replacement: passo 4, immagine 2 di 3 BlackBerry World Edition 8830 Keyboard Replacement: passo 4, immagine 3 di 3
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 Keyboard Replacement: passo 5, immagine 1 di 2 BlackBerry World Edition 8830 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 Keyboard Replacement: passo 6, immagine 1 di 3 BlackBerry World Edition 8830 Keyboard Replacement: passo 6, immagine 2 di 3 BlackBerry World Edition 8830 Keyboard Replacement: passo 6, immagine 3 di 3
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
  7. BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: passo 7, immagine 1 di 3 BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: passo 7, immagine 2 di 3 BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: passo 7, immagine 3 di 3
    • Remove the keyboard from the front casing.
Conclusione
Cal Poly, Team 17-27, Amido Spring 2012 Membro di Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 542
