Salta al contenuto principale
BlackBerry Tour 9630 Keypad Replacement
Cosa ti serve
  1. BlackBerry Tour 9630 Keypad Replacement, Battery: passo 1, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Position the phone so that the keyboard is facing down and the back is facing up.
  2. BlackBerry Tour 9630 Keypad Replacement: passo 2, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement: passo 2, immagine 2 di 2
    • Push the center silver button upwards to release the back cover.
    • Take the back cover off and set it to the side.
  3. BlackBerry Tour 9630 Keypad Replacement: passo 3, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement: passo 3, immagine 2 di 2
    • Grip the battery where the light grey half circles are located and pull up.
    • Set the removed battery to the side with the back cover.
  4. BlackBerry Tour 9630 Keypad Replacement, Keypad: passo 4, immagine 1 di 1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 Keypad Replacement: passo 5, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement: passo 5, immagine 2 di 2
    • Using an opening tool, pry the top plastic covering off. As shown in the second picture.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 Keypad Replacement: passo 6, immagine 1 di 1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 Keypad Replacement: passo 7, immagine 1 di 1
    • Remove the back casing.
    • This may take some wiggling to fully remove the part.
  8. BlackBerry Tour 9630 Keypad Replacement: passo 8, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement: passo 8, immagine 2 di 2
    • Using a small opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 Keypad Replacement: passo 9, immagine 1 di 2 BlackBerry Tour 9630 Keypad Replacement: passo 9, immagine 2 di 2
    • Using a small opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 Keypad Replacement: passo 10, immagine 1 di 1
    • Gently push up on the keyboard from below to snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 Keypad Replacement: passo 11, immagine 1 di 1
    • Remove the keypad.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 651
