Salta al contenuto principale
BlackBerry Storm 9530 Logic/Motherboard Replacement
Cosa ti serve
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, immagine 1 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, immagine 2 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, immagine 3 di 3
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 4, immagine 1 di 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, immagine 1 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, immagine 2 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, immagine 3 di 3
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, immagine 1 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, immagine 2 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, immagine 3 di 3
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 7, immagine 1 di 1
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 8, immagine 1 di 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 8, immagine 2 di 2
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, immagine 1 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, immagine 2 di 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, immagine 3 di 3
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
Conclusione
Altre 6 persone hanno completato questa guida.
Josh Forester
Membro da: 11/28/10
2.505 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 9,572
