Salta al contenuto principale
BlackBerry PlayBook Speaker Replacement
Cosa ti serve
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: passo 1, immagine 1 di 2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: passo 1, immagine 2 di 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: passo 2, immagine 1 di 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: passo 3, immagine 1 di 2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: passo 3, immagine 2 di 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: passo 4, immagine 1 di 2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: passo 4, immagine 2 di 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: passo 5, immagine 1 di 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: passo 6, immagine 1 di 2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: passo 6, immagine 2 di 2
    • Lift the right speaker bar to remove it.
Conclusione
Nathan
Membro da: 10/12/14
661 Reputazione
4 Guide realizzate
Cal Poly, Team 14-27, Maness Fall 2014 Membro di Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 980
