Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Your work area should be clean, lint-free, and with adequate lighting to visualize small print or parts.
The keypad and navigation ball may become loose and fall away from the motherboard, use caution so these items are not lost or damaged.
Parti
Nessuna parte specificata.
  1. Remove the rear cover from the phone. Remove the battery.
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. Using a small plastic opening tool, remove the lower rear cover.
    • Using a small plastic opening tool, remove the lower rear cover.
  3. Remove the six screws from the midframe of the device.
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. Remove the midframe from the phone.
    • Remove the midframe from the phone.
  5. Gently pry the back the plastic tabs that secure the motherboard to the case. Slowly work your way around the case with the tabs until the motherboard comes free.
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Conclusione
Use the new case and reassemble the phone by doing the instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Renae Bishop
Membro da: 07/09/2011
68 Reputazione
4 Guide realizzate
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,151
