Salta al contenuto principale
BlackBerry Curve 8900 Case Replacement
Cosa ti serve
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: passo 1, immagine 1 di 2 BlackBerry Curve 8900 Case Replacement, Removing the Case: passo 1, immagine 2 di 2
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: passo 2, immagine 1 di 1
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: passo 3, immagine 1 di 1
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: passo 4, immagine 1 di 1
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: passo 5, immagine 1 di 2 BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: passo 5, immagine 2 di 2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Conclusione
Use the new case and reassemble the phone by doing the instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Renae Bishop
Membro da: 09/07/11
68 Reputazione
4 Guide realizzate
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
Un commento
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,313
