Salta al contenuto principale
BlackBerry Curve 8900 Battery Replacement
  1. BlackBerry Curve 8900 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Battery Replacement: passo 2, immagine 1 di 2 BlackBerry Curve 8900 Battery Replacement: passo 2, immagine 2 di 2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
Conclusione
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
Un commento
were do i get one
Hooman Afshari - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,257
