Cosa ti serve
Place the phone on a flat surface with the screen facing down.
Remove the plastic backplate by pulling up on the bottom of the cover.
Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
Flip the phone over so the keyboard faces up.
Insert a plastic spudger into the screen where speaker resides.
I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
Gently lift up plastic screen cover until screen cover separates from screen.
Continue until screen cover is completely removed.
To reassemble the device, follow the instructions in reverse order.
Altre 4 persone hanno completato questa guida.
Un commento
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
