Salta al contenuto principale
BlackBerry Curve 8520 LCD Screen Replacement
Cosa ti serve
  1. BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: passo 1, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 LCD Screen Replacement, Battery: passo 2, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement, Battery: passo 2, immagine 2 di 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: passo 3, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement, Keyboard Cover: passo 3, immagine 2 di 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 LCD Screen Replacement: passo 4, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 LCD Screen Replacement: passo 5, immagine 1 di 3 BlackBerry Curve 8520 LCD Screen Replacement: passo 5, immagine 2 di 3 BlackBerry Curve 8520 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 LCD Screen Replacement: passo 6, immagine 1 di 3 BlackBerry Curve 8520 LCD Screen Replacement: passo 6, immagine 2 di 3 BlackBerry Curve 8520 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: passo 7, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 LCD Screen Replacement: passo 8, immagine 1 di 2 BlackBerry Curve 8520 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Conclusione
Altre 10 persone hanno completato questa guida.
Matt
Membro da: 04/07/11
1.722 Reputazione
5 Guide realizzate
Cal Poly, Team 9-62, Walters Spring 2011 Membro di Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 35,842
