Salta al contenuto principale
BlackBerry Curve 8310 LCD Screen Replacement
Cosa ti serve
  1. BlackBerry Curve 8310 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 LCD Screen Replacement, Lens: passo 3, immagine 1 di 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 LCD Screen Replacement: passo 6, immagine 1 di 3 BlackBerry Curve 8310 LCD Screen Replacement: passo 6, immagine 2 di 3 BlackBerry Curve 8310 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 LCD Screen Replacement, Keyboard: passo 7, immagine 1 di 1
    • Remove the keyboard.
  8. BlackBerry Curve 8310 LCD Screen Replacement, Screen Housing: passo 8, immagine 1 di 1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. BlackBerry Curve 8310 LCD Screen Replacement: passo 9, immagine 1 di 2 BlackBerry Curve 8310 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Now remove the left and right side panels.
  10. BlackBerry Curve 8310 LCD Screen Replacement: passo 10, immagine 1 di 3 BlackBerry Curve 8310 LCD Screen Replacement: passo 10, immagine 2 di 3 BlackBerry Curve 8310 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. BlackBerry Curve 8310 LCD Screen Replacement, LCD Screen: passo 11, immagine 1 di 1
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. BlackBerry Curve 8310 LCD Screen Replacement: passo 12, immagine 1 di 1
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
Conclusione
Altre 4 persone hanno completato questa guida.
Mandy Chan
Membro da: 01/20/12
91 Reputazione
2 Guide realizzate
Cal Poly, Team 10-32, Amido Winter 2012 Membro di Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,753
