Introduzione
This guide will help you replace the screen of your BlackBerry and extend the device's lifespan, reducing e-waste. A working screen is one of the most important parts of an electronic device. Replacing screens can be an involved process, but following these steps will make the job easier.
Cosa ti serve
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Flip the motherboard over so that the LCD display is flush with the surface of your work space.
Use a plastic opening tool to gently pry up the ribbon connector located on the left hand side of the motherboard.
Use a plastic opening tool to pry the LCD display off the board.
Removing the trackpad prior to this repair is optional. If you wish to do so, follow this guide for removal instructions.
Altre 6 persone hanno completato questa guida.
