Salta al contenuto principale
BlackBerry Bold 9700 Keyboard Replacement
Cosa ti serve
  1. BlackBerry Bold 9700 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the back panel by sliding it downward and lifting it away from the phone.
  2. BlackBerry Bold 9700 Keyboard Replacement: passo 2, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 2, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 2, immagine 3 di 3
    • Remove the battery by lifting the bottom edge of the battery from the bottom of the phone and up from the case.
    • (Warning: Power-off the device before removing the battery.)
  3. BlackBerry Bold 9700 Keyboard Replacement: passo 3, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 3, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 3, immagine 3 di 3
    • Remove the SIM card by pushing the card vertically through the bracket towards the top of the device.
    • The SIM card MUST be removed to disassemble the device.
  4. BlackBerry Bold 9700 Keyboard Replacement: passo 4, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 4, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to gently pry the bottom panel with the AT&T logo away from the phone.
    • Note: You will hear a snapping sound.
  5. BlackBerry Bold 9700 Keyboard Replacement: passo 5, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 5, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 5, immagine 3 di 3
    • Remove the front panel 5.57mm Torx head screws x2 with the T5 Torx screwdriver.
  6. BlackBerry Bold 9700 Keyboard Replacement: passo 6, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 6, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the plastic opening tool to remove the frame.
    • This will take a bit of effort. You will hear a snapping sound.
  7. BlackBerry Bold 9700 Keyboard Replacement: passo 7, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 7, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 7, immagine 3 di 3
    • Gently lift the bottom of the keyboard up with your fingers and pull it toward the bottom of the phone.
  8. BlackBerry Bold 9700 Keyboard Replacement: passo 8, immagine 1 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 8, immagine 2 di 3 BlackBerry Bold 9700 Keyboard Replacement: passo 8, immagine 3 di 3
    • Align the new keyboard to the bottom of the screen with the track pad slot angled downward.
    • Once the keyboard is flush with the screen, push the keyboard into place.
Conclusione
To reassemble your device, follow these steps in reverse.
Danny
Membro da: 03/11/15
365 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,211
