Salta al contenuto principale
BlackBerry 8820 Trackball Replacement
Cosa ti serve
  1. BlackBerry 8820 Trackball Replacement, Disassembling BlackBerry 8820 Outer Casing: passo 1, immagine 1 di 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Trackball Replacement: passo 2, immagine 1 di 2 BlackBerry 8820 Trackball Replacement: passo 2, immagine 2 di 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Trackball Replacement: passo 3, immagine 1 di 2 BlackBerry 8820 Trackball Replacement: passo 3, immagine 2 di 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Trackball Replacement: passo 4, immagine 1 di 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Trackball Replacement: passo 5, immagine 1 di 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Trackball Replacement, Track Ball: passo 6, immagine 1 di 1
    • After removing the front from the outer casing, the track ball will come off attached to the casing.
  7. BlackBerry 8820 Trackball Replacement: passo 7, immagine 1 di 1
    • Remove the track ball from the front case.
Conclusione
Altre 3 persone hanno completato questa guida.
ryan
Membro da: 04/12/13
44 Reputazione
5 Guide realizzate
Cal Poly, Team 13-64, Johann Spring 2013 Membro di Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 857
