Salta al contenuto principale
BlackBerry 8700c Replacing Logic Board Replacement
Cosa ti serve
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: passo 1, immagine 1 di 2 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: passo 1, immagine 2 di 2
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: passo 2, immagine 1 di 2 BlackBerry 8700c Replacing Logic Board Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: passo 3, immagine 1 di 1
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: passo 4, immagine 1 di 2 BlackBerry 8700c Replacing Logic Board Replacement: passo 4, immagine 2 di 2
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: passo 5, immagine 1 di 2 BlackBerry 8700c Replacing Logic Board Replacement: passo 5, immagine 2 di 2
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: passo 6, immagine 1 di 3 BlackBerry 8700c Replacing Logic Board Replacement: passo 6, immagine 2 di 3 BlackBerry 8700c Replacing Logic Board Replacement: passo 6, immagine 3 di 3
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
Conclusione
arlebrun
Membro da: 12/02/09
1 Reputazione
1 Guida realizzata
Cal Poly, Team 18-4, Maness Fall 2009 Membro di Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,228
