Salta al contenuto principale
BlackBerry 7510 Logic Board Replacement
Cosa ti serve
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: passo 1, immagine 1 di 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: passo 2, immagine 1 di 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: passo 3, immagine 1 di 1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: passo 4, immagine 1 di 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: passo 5, immagine 1 di 2 BlackBerry 7510 Logic Board Replacement: passo 5, immagine 2 di 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: passo 6, immagine 1 di 1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: passo 7, immagine 1 di 1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: passo 8, immagine 1 di 1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: passo 9, immagine 1 di 1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: passo 10, immagine 1 di 2 BlackBerry 7510 Logic Board Replacement: passo 10, immagine 2 di 2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: passo 11, immagine 1 di 2 BlackBerry 7510 Logic Board Replacement: passo 11, immagine 2 di 2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
Conclusione
Neil Johnson
Membro da: 01/24/10
12 Reputazione
6 Guide realizzate
Cal Poly, Team 14-44, Regan Winter 2010 Membro di Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,867
