Salta al contenuto principale
BlackBerry 7510 Back Face of Phone Replacement
Cosa ti serve
  1. BlackBerry 7510 Back Face of Phone Replacement, Back Face of Phone: passo 1, immagine 1 di 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Back Face of Phone Replacement: passo 2, immagine 1 di 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Back Face of Phone Replacement: passo 3, immagine 1 di 1
    • Lift off the back cover.
  4. BlackBerry 7510 Back Face of Phone Replacement: passo 4, immagine 1 di 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Back Face of Phone Replacement: passo 5, immagine 1 di 2 BlackBerry 7510 Back Face of Phone Replacement: passo 5, immagine 2 di 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
Conclusione
Cal Poly, Team 14-44, Regan Winter 2010 Membro di Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,547
