Salta al contenuto principale
BlackBerry 7280 Front Case Replacement
Cosa ti serve
  1. BlackBerry 7280 Front Case Replacement, Battery: passo 1, immagine 1 di 3 BlackBerry 7280 Front Case Replacement, Battery: passo 1, immagine 2 di 3 BlackBerry 7280 Front Case Replacement, Battery: passo 1, immagine 3 di 3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Front Case Replacement: passo 2, immagine 1 di 2 BlackBerry 7280 Front Case Replacement: passo 2, immagine 2 di 2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Front Case Replacement, SIM Card: passo 3, immagine 1 di 3 BlackBerry 7280 Front Case Replacement, SIM Card: passo 3, immagine 2 di 3 BlackBerry 7280 Front Case Replacement, SIM Card: passo 3, immagine 3 di 3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Front Case Replacement, Back Case: passo 4, immagine 1 di 2 BlackBerry 7280 Front Case Replacement, Back Case: passo 4, immagine 2 di 2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Front Case Replacement: passo 5, immagine 1 di 2 BlackBerry 7280 Front Case Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Front Case Replacement, Front Case: passo 6, immagine 1 di 2 BlackBerry 7280 Front Case Replacement, Front Case: passo 6, immagine 2 di 2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Front Case Replacement: passo 7, immagine 1 di 2 BlackBerry 7280 Front Case Replacement: passo 7, immagine 2 di 2
    • Remove the front plastic case from the metal bracket.
Conclusione
Clemson, Team 12-2, Benson Spring 2013 Membro di Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 216
