Salta al contenuto principale
BlackBerry 7130e battery replacement
Cosa ti serve
  1. BlackBerry 7130e battery replacement, battery: passo 1, immagine 1 di 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: passo 2, immagine 1 di 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: passo 3, immagine 1 di 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Conclusione
Cal Poly, Team 3-16, Maness Winter 2010 Membro di Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,976
