Salta al contenuto principale
BlackBerry 7100g Housing Replacement
Cosa ti serve
  1. BlackBerry 7100g Housing Replacement, Battery: passo 1, immagine 1 di 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Housing Replacement: passo 2, immagine 1 di 3 BlackBerry 7100g Housing Replacement: passo 2, immagine 2 di 3 BlackBerry 7100g Housing Replacement: passo 2, immagine 3 di 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Housing Replacement: passo 3, immagine 1 di 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Housing Replacement, Housing: passo 4, immagine 1 di 3 BlackBerry 7100g Housing Replacement, Housing: passo 4, immagine 2 di 3 BlackBerry 7100g Housing Replacement, Housing: passo 4, immagine 3 di 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Housing Replacement: passo 5, immagine 1 di 2 BlackBerry 7100g Housing Replacement: passo 5, immagine 2 di 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Housing Replacement: passo 6, immagine 1 di 3 BlackBerry 7100g Housing Replacement: passo 6, immagine 2 di 3 BlackBerry 7100g Housing Replacement: passo 6, immagine 3 di 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Housing Replacement: passo 7, immagine 1 di 1
    • You can now easily remove the "guts" of the phone from the housing.
Conclusione
Kellan
Membro da: 03/30/10
277 Reputazione
3 Guide realizzate
Cal Poly, Team 25-87, Amido Spring 2010 Membro di Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,257
