Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide describes how to replace the battery contact terminal, where the BlackBerry 7100g battery connects to the phone.
  1. Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. Push down on the release button with one thumb. Slide the battery cover off with the other thumb. Slide the battery cover off with the other thumb.
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. Remove the battery from the battery housing by flipping up the top of the battery.
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Locate the silver strip near the top of your BlackBerry. Use a plastic opening tool to pry off the edge of the silver lining. Slide the tool along the length of the silver strip to completely remove it.
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  6. Do not lose the screws. They are quite small and can easily be misplaced. Locate and unscrew the four (4) screws using a T6 screwdriver.
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  7. The keypad cover may fall out of the housing when prying the housing apart. Tightly pinch the top of the front and back halves of the housing. Carefully pry the two halves of the housing apart.
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  8. You can now easily remove the "guts" of the phone from the housing.
    • You can now easily remove the "guts" of the phone from the housing.
  9. Remove the four screws holding the battery and speaker housing to the motherboard. Remove the four screws holding the battery and speaker housing to the motherboard.
    • Remove the four screws holding the battery and speaker housing to the motherboard.
  10. Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing. The small plastic piece with four metal pins is the battery terminal shown in the third picture. The small plastic piece with four metal pins is the battery terminal shown in the third picture.
    • Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing.
    • The small plastic piece with four metal pins is the battery terminal shown in the third picture.
Conclusione
Kellan
Membro da: 30/03/2010
274 Reputazione
3 Guide realizzate
Cal Poly, Team 25-87, Amido Spring 2010 Membro di Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,935
