Salta al contenuto principale
Black and Decker WP900 Power Switch Replacement
Cosa ti serve
  1. Black and Decker WP900 Power Switch Replacement, Power Switch: passo 1, immagine 1 di 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Switch Replacement: passo 2, immagine 1 di 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Switch Replacement: passo 3, immagine 1 di 3 Black and Decker WP900 Power Switch Replacement: passo 3, immagine 2 di 3 Black and Decker WP900 Power Switch Replacement: passo 3, immagine 3 di 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Switch Replacement: passo 4, immagine 1 di 1
    • Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Switch Replacement: passo 5, immagine 1 di 2 Black and Decker WP900 Power Switch Replacement: passo 5, immagine 2 di 2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top
  6. Black and Decker WP900 Power Switch Replacement: passo 6, immagine 1 di 1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel will be attached to magnet body.
  7. Black and Decker WP900 Power Switch Replacement: passo 7, immagine 1 di 1
    • Remove the switch from the wires.
    • Gently, pull and release the two wired connections.
    • The switch can now be replaced. Be sure not to damage the two connections to the control module in the process.
Conclusione
Cameron
Membro da: 02/15/16
231 Reputazione
2 Guide realizzate
IUPUI, Team 8-8, Wilson Spring 2016 Membro di IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 990
