Introduzione
To work on the inside of the toaster, the top cover must first be removed. This guide provides instructions on how to remove the top cover.
Cosa ti serve
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
Altre 2 persone hanno completato questa guida.
