Salta al contenuto principale
Black and Decker SS12C Battery Replacement
Cosa ti serve
  1. Black and Decker SS12C Battery Replacement, Battery: passo 1, immagine 1 di 3 Black and Decker SS12C Battery Replacement, Battery: passo 1, immagine 2 di 3 Black and Decker SS12C Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: passo 2, immagine 1 di 1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: passo 3, immagine 1 di 3 Black and Decker SS12C Battery Replacement: passo 3, immagine 2 di 3 Black and Decker SS12C Battery Replacement: passo 3, immagine 3 di 3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: passo 4, immagine 1 di 2 Black and Decker SS12C Battery Replacement: passo 4, immagine 2 di 2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: passo 5, immagine 1 di 3 Black and Decker SS12C Battery Replacement: passo 5, immagine 2 di 3 Black and Decker SS12C Battery Replacement: passo 5, immagine 3 di 3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 20
Tutti i Tempi: 837
