Salta al contenuto principale
Black and Decker Pivot Plus PD600 Motor Replacement
Cosa ti serve
  1. Black and Decker Pivot Plus PD600 Motor Replacement, Drill: passo 1, immagine 1 di 3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: passo 1, immagine 2 di 3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: passo 1, immagine 3 di 3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Motor Replacement: passo 2, immagine 1 di 1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Motor Replacement, Motor: passo 3, immagine 1 di 1
    • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
    • However, do not pull too hard because the motor is attached to other components of the drill by wires.
  4. Black and Decker Pivot Plus PD600 Motor Replacement: passo 4, immagine 1 di 2 Black and Decker Pivot Plus PD600 Motor Replacement: passo 4, immagine 2 di 2
    • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
  5. Black and Decker Pivot Plus PD600 Motor Replacement: passo 5, immagine 1 di 1
    • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 4-15, Maness Spring 2013 Membro di Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Membri
6 Guide realizzate
Un commento
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,347
