Salta al contenuto principale
Black and Decker PS1800 Transmission Replacement
Cosa ti serve
  1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: passo 1, immagine 1 di 2 Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: passo 1, immagine 2 di 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Transmission Replacement: passo 2, immagine 1 di 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: passo 3, immagine 1 di 3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: passo 3, immagine 2 di 3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: passo 3, immagine 3 di 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Transmission Replacement: passo 4, immagine 1 di 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Transmission Replacement: passo 5, immagine 1 di 2 Black and Decker PS1800 Transmission Replacement: passo 5, immagine 2 di 2
    • Remove the motor from the transmission assembly, as pictured.
  6. Black and Decker PS1800 Transmission Replacement, Transmission: passo 6, immagine 1 di 3 Black and Decker PS1800 Transmission Replacement, Transmission: passo 6, immagine 2 di 3 Black and Decker PS1800 Transmission Replacement, Transmission: passo 6, immagine 3 di 3
    • Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
  7. Black and Decker PS1800 Transmission Replacement: passo 7, immagine 1 di 1
    • Align the new transmission gears with the motor’s gears.
    • Reattach the transmission and motor by rescrewing the initial screws.
  8. Black and Decker PS1800 Transmission Replacement: passo 8, immagine 1 di 2 Black and Decker PS1800 Transmission Replacement: passo 8, immagine 2 di 2
    • Reconnect the torque adjuster to the transmission by following the procedure seen in step 6.
  9. Black and Decker PS1800 Transmission Replacement: passo 9, immagine 1 di 1
    • Reconnect black and red wires onto the motor and place the motor, transmission and torque adjuster back onto their initial location.
  10. Black and Decker PS1800 Transmission Replacement: passo 10, immagine 1 di 1
    • Reconnect the clamshell.
    • Press trigger to make sure the new transmission works.
    • Press and hold the clam-shell to assure it will not drop while testing.
Conclusione
David Nawl
Membro da: 10/19/16
279 Reputazione
2 Guide realizzate
IUPUI, Team 2-3, Baechle Fall 2016 Membro di IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,536
